P5 Installation
U
ulysses garcia 👤 Member for 20 years 10 months
Hi all,
If you need all the details for P5 installation , give me your email adress and ill be more willing to help everybody..
regards,
ULY
U
Karem wrote: the default user name & password for connection is : pubuser OR privuser..
Karem are you sure you can install P5 using default password as you mentioned.
I dont think so , the correct password is admin, i try it out and successfully installed
U
I dont think so , the password is admin, i try it out and successfully installed
K
Karim Mounir 👤 Member for 20 years 2 months
Hi Hemanth,
Try to check your database connection as follows:
1- Open the "Project Management"
2- On the window that appears click on the browse button next to the name Database.
3- Assuming that the default database name is "PMDB", select it and then click on "Configure".
4- A window appear titled "Select or create alias", select the "PMDB" database and the driver type to be "Microsoft SQL server/MSDE" then next.
5- In the window titled "Configure SQL server connection" type the following:
Host name: COMPUTERNAME\Primavera (where COMPUTERNAME is your computer name)
Database name: PMDB$PRIMAVERA
then next.
6- the default user name & password for connection is : pubuser OR privuser.
7- A window appear showing the status for this connection (successfully or not).
Hopefully this helps.
Karim
A D 👤 Member for 19 years 1 month
And whats the operting system u r using?
Xp or Vista?
VISTA doesn’t supports primavera
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
