Importing from Project to P3e
Davie Ross 👤 Member for 19 years 10 months
Thank you all for your help it would seem to be a memory problem I have now completed the import 5000 activities at a time went ok.
G
Gillan Lam 👤 Member for 19 years 9 months
Hi Gents
That happen is because it run out of resources (ie memory in your computer)
The maxiumum I had completed successfully with the top machine is approx 30,0000 activity
However you cannot over 65536 (thats excel limited)
In order to run successfully with 12,000+ Activity you need to buy some more memory (Fast one) I suggest you need to have 2G + Memory if you running it in local machine (Idealy 4G)
Good Luck
Gillian
M
Marcio Sampaio 👤 Member for 20 years 7 months
The maximum I did had 15.000 activities.
I think there is no restriction.
Regards.
Marcio Eduardo.
Thanks for the reply John I am trying to import 12000+ activities and it has stalled twice now ????
J
John Lawson 👤 Member for 21 years 8 months
Hi Davie
I have never had a problem with numbers - mind only had 2-300 sized plans to mess about with, how many do you have.
John
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
