Convert P3.1 data to 4.1 (e&c)
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Shengyen, Christian, Thanks for the advice. I have new projects already created in 4.1. I need to import the existing projects from 3.1. I shall try keeping your suggestions in mind. Thanks.
Amar
Shengyun is right.. let all the datas from you 3.1 be exported to 4.1 just to make it more intact then try to compare you 4.1 vs 3.1 datas and see for yourself if they have the same datas, only then you can start modifying your projects.. hope this helps..
Cheers!
Christian
