what is impact on schedule using negative Lag
salauddin mohamme...
User offline. Last seen 5 years 26 weeks ago. Offline
Dear all,
pls anybody adivse me why we can’t use negative lag in the schedule, The client or consultant advising no to use. Why? what is the reason.
I beleive that if we didn’t use negative lag, the schedule is not properly on critical path, hence, several activities with total float more than zero or one.
Brad Richey
User offline. Last seen 13 years 26 weeks ago. Offline
If you change the relations from FS with -ve lag to SS with +ve lag be sure to include a FF relationship between the same two items if you do not you may be finishing the successor before the predecessor completes.
Ahmad saeed
User offline. Last seen 16 years 49 weeks ago. Offline
Hi Salauddin,
Using negative lags in the relationship has no effect on the schedule.
you can change the relations from FS with -ve lag to SS with +ve lag.
Hope that this will help.
