Error # 30 - prx file restore
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Thanks for the feedback. I have deleted the PTL.P3 and TTL.p3 files and sent to them. Im waiting to hear if they get the same code again.
This error message appears if the PLT.P3 file has become damaged. As a result, this file will need to be deleted or replaced.
1. Close P3.
2. Browse to the directory where the project has been saved.
3. Delete or rename the PLT.P3 file. If possible, replace this file from a backup.
Note: This file contains the Plot specifications and will automatically get recreated when accessing the graphic reports. Deleting the PLT file will reset all the graphic reports to the default options.
