Converting to PDF
Rick Aquino
User offline. Last seen 14 years 50 weeks ago. Offline
hi all,
i can easily convert an office to pdf, but when i convert primavera file to pdf i’m strugling a lot and not giving good result or no result at all, and if i’m doing it in another computer it is working easily, using the same procedure and the same default, what is the problem with my P3? do i have a problem with my p3 or my computer?
Rick Aquino
hi guyz,
Thanks for answering my query, and John i followed your advised to download pdf995 and it works.thank you very much.i just hope this free download works forever. hehehehe thanks again
John Hartman
User offline. Last seen 11 years 29 weeks ago. Offline
I’ve had similar issues printing to PDF from P3 via Adobe PDF Writer. I’ve downloaded PDF995 (www.pdf995.com) and haven’t had any problems since.
Karim Mounir
User offline. Last seen 11 years 12 weeks ago. Offline
Also, CutePDF Writer is very good.
http://www.cutepdf.com/Products/CutePDF/writer.asp
James Barnes
User offline. Last seen 2 years 31 weeks ago. Offline
I had problems with using Adobe Acrobat to create PDFs from P3 (not sure of the SP installed on my workstation, but probably none, given our IT support)
I switched to using PDFCreator and have had no problems with it. I have read elsewhere that others have had difficulties but it works fine for me.
Dieter Wambach
User offline. Last seen 8 years 27 weeks ago. Offline
Maybe you didn’t install SP2 (or SP3) on that pc.
