Insert Logo in Primvera
Trian Asmoro
Soheil Barekat
Erkan Polater
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Thanxs guys
Now Working Perfectly
sorry yaar there is a correction
Open a word file insert your logo in word , then copy it (Select All, Ctrl+C). Then open the pmt program, select new then paste it(select edit -paste). then save it the file is in pmt now
regards
deb
hi faizz,
I hope i told u , that u need pmt file .follow this-Open your logo in jpeg file..then copy it (Select All, Ctrl+C). Then open the pmt program, select new then paste it. then save....
HTH
Deb
hi
Sap syed
what service pack of p3 are u using.
coz i can import a .bmp file in my softwaare its service pack 3.
hope it helps
cheers
mangesh
Dear thankx for your repley . Still its not working . My Logo is .BMP file . Error Msg says that i have to convert to .PMT . How Can i do that .
Hi Syed,
You can insert logos in header/Footer & it can be either pmt, bmp, metafile or a word one.
If the desired location is elsewhere, use the insert function.
cheers
dattatreya
hi
SAP syed
do one thing go to insert menu, click on object a window will pop up and it has all the other options by using which u can get ur task accomplished.
cheers
mangesh
Hello i hope u want o insert logo at the bottom row , go to print preview, there u have footer , in footer select logo , which should be a PMT file.
regards
deb
