Importing activities from P3 to Suretrack
N
Naomi Quan 👤 Member for 20 years 8 months
One last thing; Hammocks in P5 are different from those in P3. P3 hammocks are very ’picky’ and may only be related in the manner described below.
P5 Hammocks can use any type of relationship (and give quite some odd results for ’non-standard’ arangements.) Hammocks that ’work’ in P5 may not work in P3. Good luck!
Alex Wong 👤 Member for 23 years 4 months
Naomi
I think hammock does work in Suretrak as well as P3e or P3
and what Ronald said is you need to have the right relationship to drive the hammock correctly
Alex
N
Thanks for your comments.
But why does the hammock work in P3 and P3e but not in suretrack.
The problem is with your hammock activity. It does not have a legal start-to-start predecessor. Hammocks only observe start-to-start predecessors and finish-to-finish successor relationships. All other relationships are ignored.
Without a proper start-to-start predecessor, hammocks always begin at the data date. Without a proper finish-to-finish successor relationship, hammocks always end at project completion. Hammocks do not obey constraints set against them. Good luck!
K
Kevin Button 👤 Member for 22 years 11 months
Naomi
If you post your question in the P3 forum I am sure somebody will have an answer for you.
KB
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
