Discripency p3 Screen and Report
Erim INANC
gorilpk
Ricky
pinoyplanner
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
Mohammed Netarwala
Moahmed
Are you looking at the same thing ?????
If we dont understand what you are looking at we can not tell you what is wrong. If we dont understand what is wrong then the only advice we can suggest is to hire a qaulified planner who can do the job.
Tell me have you had a look at the Filter and Resource selection are they the same on both screens. (Remember a filter has more than one lvl.)
When you export what method do you use are you exporting a report that is based time or on actualy value.
You see you need to be specific.
Jaco Stadler
I m not concern about the type report, my concern is why same date item ( Budget Quantity )shoes different value in p3 refold screen and the resource tabular report
Azvi
I am going to make some assumptions.
You are talking about Earned Value.
You are using RT-01 Report.
You need to check the following.
1) Filters
2) Data Date / Time Period
3) Also remember when p3 exports it works with period beginning.
The Value in your P3 Screen BQWP (Earned Value Should be the correct value)
Hi Which Reports are you talking about.
Maybe you have applied a Filter
Jaco Stadler
I have to produce s- curve for the latest updated schedule which i have received from the contractor, S-curve to be produce based on the effort, In the program all the resources unites are in man hour.
I have seen B.Q in the p3 screen and tabular report has different value.
could you advise me what will be the issue?
Best Regard
Azvi
Please define which reports you are running.
