P3 to Excel conversion
bal aji
Lee Mallek
Syed Shoeb
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
Dimitrios Theocharidis
By RA, which is available in CD, can export P3 into Excel format.
The revised data in Excel can be imported back to P3.
To make the s-curve in P3, with the bar chart, use the View->Resource profile (CTRL+F7) option.
Then in the window select the resource You want to show in Your gph, as well as the display option.
To have it print, in page set up You have to flag in the “Resource/Cost display”
To exchange info between P3 and excel You can also do in other two way:
- importing and exporting the information You need;
- Using the ODBC driver capability.
Over the RA engine as per mktse post.
I hope is what You were looking for.
