BL Project Finish not matching BL Project Early Finish
Mark Sumner
User offline. Last seen 11 years 25 weeks ago. Offline
I am trying to show my baseline bars and it seems they are pulling from the BL Project Finish dates which are not correct and do not match the BL Project Early Finish Dates
1. How can I correct this so my BL Project Finish dates match the BL Project Early Finish dates(which are correct)?
2. is there a setting to have the bars reference the BL Project early finish dates and not the useless Project Finish Dates.
If by global change can you please post the setup as I can not seem to create the proper global change to make it work.
Mark
Gary Whitehead
User offline. Last seen 6 years 15 weeks ago. Offline
Mark,
Not entirely sure I understand your query, but I think if you read the following it will solve your issue:
http://eastwoodharris.com/DL/TP/110616_P6_V7_What_Baseline_Bars_am_I_Displaying.pdf
G
User offline. Last seen 42 weeks 21 hours ago. Offline
Hi Mark.
It is the most likely result that the logic linked baseline programme will not equate to the contract completion date.
In fact if it does match exactly it is a sign that the programme has been rigged to suit.
