WBS for EPC project (engineering-procurement-contstruction)
6 replies [Last post]
Alessandro Gebbia
User offline. Last seen 9 years 47 weeks ago. Offline
Hello friends, I have been asked to develop an EPC work-breakdown. I just completed the construction wbs but i have no ideas about E and P, I am too new in this field. Would you please suggest me an example or an already made structure so I can start working on it and adequate it to my needs?
Thank you very much
Anoon Iimos
User offline. Last seen 3 years 41 weeks ago. Offline
Ideally, you should never develop WBS on your own. It should always be a team effort corresponding to concerned disciplines or specialties. Like for example: You were asked to develop a process flow diagram when you were never a process engineer. So how could you be able to do that? However, reality in construction projects is so difficult to understand or managed. And just ultimately resulting to whatever they can just do best and fast (even copying other works that were totally different from what they intend to do), only to satisfy some stupid contract requirements or not defaulting the contract. So still wondering why most construction projects (if not all) fail? Or always spending beyond budget and always late?
dhon bartolome
User offline. Last seen 36 weeks 3 days ago. Offline
hi,
Simple WBS
Enggineering
    > Submissions (Drwgs)
    > Review and Approval (Drwgs)
Procurement
   > Submissions (Material/Technical)
   > Review and Approval (Material/Technical)
   > P.O
   > Fabrication/Manufacturing Cycle
   > Onsite Deliveries
masoud sedaghat
User offline. Last seen 6 years 40 weeks ago. Offline
Hi . I Need WBS for EPC Project
Dinesh Kumar
User offline. Last seen 6 years 3 weeks ago. Offline
A raw example (curtailed version) of a typical FPSO project WBS may look like
PHASES
                Milestones,Management
                Engg, Proc,  Const
WORK PACKAGES
                Vessel
                Topsides & Process
                Turret & Mooring
                Subsea system etc
AREA/MODULES
                Gas Compression
                Polishing
                K O Drum
              Power Generation / LocEqpRm
                Utilities
                Helideck
DISCIPLINES
                SMP E&I
MISC
Project Name
  1. Milestone
  2. Project Management
  3. Statuary Approvals
  4. ENGINEERING
    1. client deliverables
    2. Detailed dwg development & Approvals
    3. QC documents
  5. PROCUREMENT
  6. CONSTRUCTION
  7. Completion & COMMISSIONING
  8. Load-out / Handover
Evaristus Ujam
User offline. Last seen 13 years 13 weeks ago. Offline
Just for the sake of emphasis,  your WBS  for engineering and procurement  in a typical  Oil and gas environment may  look like this:
(1) Process, Mechanical, E & I Design
(2) Location (pipe racks, Flare, inlet manifolds, utility area,etc)
(3) Work items (pipes, KOD, Tank, heaters Pumps, valves, etc)
(4) Deliverables(P&IDs, Plot plans, Isometrics, etc)
Procurement
(1)Discipline ( Civil/structural, M&E, Instrument)
(2) categories ( local, Foreign)
(3) Shipment (Discuss methology & procurement sequence with experts in procurement Dept)
(4) Work item (equipment, valves, pumps, specialists of diff trades).
Note that process leads in engineering while  Civil structural activities take precedence in most construction activities.
Ujam
Gary Whitehead
User offline. Last seen 6 years 21 weeks ago. Offline
wbs = work breakdown structure. the clue is in the name. How do your engineering & procurement departments breakdown their work?
They might break it down like the following example, they might not. Speak to them to find out
1) Engineering
2) Discipline (civ, mech, elec, etc)
3) Sub-discipline (groundworks, paving, buildings, etc)
4) Area / workfront / whatever you call it
5) Deliverable type (calcs, drawing, survey, etc)
1) Procurement
2) Discipline
3) Procurement Item (rebar, piling contractor, etc)
