Infrastructure Project Productivity Rate
J
James bid 👤 Member for 16 years 9 months
T
Tommy James Nuneza 👤 Member for 10 years 8 months
Hello James,
How you found any availalbe templates regarding your concern?
Regards/COcoy
C
cutepriya civil 👤 Member for 15 years 2 months
hi..can anybody please send productivity or manpower output norms of buildings...
Alex Thompson 👤 Member for 15 years 2 months
Caterpillar, the biggest heavy equipment manufacturer and 4th-largest exporter on the globe, reported record profits Friday. I read more information here: Caterpillar records record $1.22 billion profit for Q1 2011.
Figures point to a $1.22 billion profit, 426 % higher than First quarter last year. Sales increased 57 % to $12.95 billion over the same period. Caterpillar managed to stay in business amidst recession. Cheers!
N
Nelson TJ 👤 Member for 19 years 8 months
Would you please send me infratsructure productivity rate if you have? including sewer network, storm water, electrical netork, etc....
my email ID is [email protected]
Thanks & Best regards
Nelson
J
Jeff,
Can you please resend because i didnot receive.
use the private message service
A D 👤 Member for 19 years 1 month
If u r looking for book, then chk this:
Construction Planning, Equipment, and Methods - by RL Peurifoy.
This is the best book on Equipment Managment and productivity calculation
M
Hi Rafael
I do not use production rates for resource modelling.
Even if I wanted to I could not access the PP rates section because I have not introduced enough members.
I extract the resource hours from the cost plan / BOQ and use the total hours to allocate to the tasks.
Mike,
Your postings about earthwork production rates are the correct way to estimate excavation output. It is not as simple as a single number as posted under PP Rates. PP Rates can be misleading as they miss a big part of the picture. Not only earthwork is interesting but formwork using several methods, especially if unconventional such as slip forming.
Discussion of production rates is a much needed title, we should raise the bar.
I would suggest that when you click at Rates this would get you to a forum for this purposes, where everyone would post production rates and the logic behind it in appropriate threads. It will also relieve some burden on PP Admin.
M
Hi Christopher
Excavation output is not determined by the rate of excavation - you can find the listed performance ratings on any manufacturers website.
You have to calculate the haul & disposal rate for the excavated material.
This is a formula based on:
Haul distance
Paylod of haul equipment
Load and tip time
Haul speed KMH
When you have calculated the haul time you can balance the excavation rate by the number of haul units.
Aim to have enough units so that the excavator is working at about 80% capacity.
PS I am moving this thread to the planning discussion section.
J
Thanks Samer!
Can you share it to me the websites so that i can download all the Productivity rates
How about the manpowers? as what i asked to Raviraj? do you have standard productivity rate? Can you share it to me also?
I know you are now " high Caliber" in planning because of your experience.
I hope you could help me.
J
Thanks Raviraj!
Actually , It is underpass and Bridge.
I want to know the excavation rate for all the equipments that will be used, Manpower to be used including steel fixers, masons , carpenters.
If you have can you email me in (please contact christopher by the private message service.)
Many Thanks
S
Samer Zawaydeh 👤 Member for 17 years 11 months
Dear Chris,
It depends on the type of soil layers and the equipment that you are using. It is a broad range. I would recommend that you read the soil reports and discuss with your construction team the type of equipment that they are considering.
Subsequently, you can download the charts from the website of the equipment companies and factor in the skilled operators expected productivity.
With kind regards,
Samer
Infrastructure project?
Road / Utility Services / Pipeline / Industrial Plants ???
type of project?
Adrian Fletcher
GeoVe
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
Johannes Vandenberg
Soheil Barekat
