Weight percentages
B
Binish Toor 👤 Member for 18 years 3 months
Yes, you can assign dates to Steps, but they will not ‘roll-up’ to your activity dates. Just add two User-Defined-Fields (UDF) to your Steps tab and make then data type: Date. Title the fields with “Start” and “Finish” or whatever you like. Good luck!
asyraf mr 👤 Member for 16 years 9 months
Can we assign dates to the steps? it could be the planned or target dates to achieve the identified steps
S
Shahzad Sikandar 👤 Member for 20 years 4 months
Please ignore last two replies.
hope this one apears all right on the web page.
Percntage.
Is the amount of work done in terms of physical % complete or duration % complete or units % complete.
Whichever you are using in Primavera P5. value for this ranges between 0-100.
Weight Percentage and Weight.
Lets sey you have an activity which will be complete when A, B and C will be completed ( consider A, B and C as steps to that activity)
Now
You have to assign weight to each of this step,, how imp it is or what proportion of work it will cover for an activity
Just for an example.
Activity A
weight % = 40
weight = 2.0
Activity B
weight % = 40
weight = 2.0
Activity C
weight % = 20
weight = 1.0
When you change weight , percent weight should change automatically..
Lets suppose there are only 2 steps, so
Activity A
weight % = 50
weight= 2.0
Activity B
weight% = 50
Weight = 2.0
Hope this helps.
If I am incorrect please correct me.
Keep asking and answering
S
Percntage.
Now
Activity steps weight (%) weight
Activity A 40 2.0
Activity B 40 2.0
Activity C 20 1.0
Activity A 50 2.0
Activity B 50 2.0
Hope this helps.
S
Percntage.
Now
Activity steps percent weight (%) weight
Activity A 40 2.0
Activity B 40 2.0
Activity C 20 1.0
Activity A 50 2.0
Activity B 50 2.0
Hope this helps.
Syed Shoeb
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
