"KingPin" Retaining Wall
Erim INANC
gorilpk
Ricky
pinoyplanner
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
Mohammed Netarwala
Moahmed
Andrew
You are SOOOO not Wrong !!!!!!!!!
In Romania they have a similar solution for temporary earthwork support. "A Berlin Wall" In this case H section steels are driven or bored into the ground and timbers placed between the web of the steel to retain earth.
Dorchesters a long way from Kent! Hope your passport is in order and watch out for the "moon rakers"!
Clive
Thanks for that, I think I need to talk to the Engineer, at least I know what they are suggesting now
Best Regards
Andrew
Chris and Clive
Thanks for your input - I assume that I could go for a pre-cast solution for the wall, or even use the pre-cast as a back shutter ?
Best Regards
Andrew
Hi Andrew,
This is out of my area, but is this the same thing as an anchored retaining wall?
Chris
