Text will not wrap after Import from Excel
T. Barnes
User offline. Last seen 6 years 37 weeks ago. Offline
Hello all,
I have successfully imported data to P6 via XL. I have some rather long "Activity Names" that refuse to wrap inside the field.
I have tried ALL "Table Row & Font" settings to no avail.
IF I copy the text into MS Word, then paste it back into the field it will wrap!
Thoughts?
User offline. Last seen 14 weeks 4 days ago. Offline
Go back to your original XLS import file, for the activities with long descriptions, go into that particular cell, find the point where you want the line to wrap and press ALT+ENTER
You could even build a formula that does a replace for any description over a certain length such as:
=LEFT(B2,50)&"
"&MID(B2,51,250)
Where 50 is the length you want to wrap at, and press ALT+ENTER to create the linebreak.
Then reimport to overwrite the existing Activity Descriptions, and use Zoltan's method to increase row heights.
T. Barnes
Thanks for taking time to reply.
I tried your method Zoltan Palffy.
Didn't work.
User offline. Last seen 1 day 17 hours ago. Offline
here is a trick ot get it to work
go to view table front and row
now uncheck Keep Current Row Heights
Check Optimize Height by row content and under that select Do not exceed and use 2 lines per row select APPLY and nothing happens
NOW under that click on Select height for all rows and select 22 and then click APPLY
now Check Optimize Height by row content and under that select Do not exceed and use 2 lines per row
next select APPLY then select OK
this is a little work around that you can use
In your Excel import file, if you force a line break in a description cell, this should import into P6. Be warned though, it wil screw up any exports to xls, or reports to csv output.
