PMSDK.ini file missing error during SDK setup
Anyone who is using P6 SDK successfully should be able to help with my error. I am using 32-bit P6 v7 with 32-bit ODBC data source and 32-bit excel. For some reason I can't get SDK to work.
My error:
Row 0: RDA error: Resource not available - Connect error: da=PMSDK;Driver=PMSDK;engine=PM;lf=C:\temp\PMSDK.LOG;lo=terse;pg=1;pp=pubuser;pu=pubuser;. Error returned from engine: VDB.Connect; Exception=TCIniFile.Create: Unable to locate .ini file, C:\WINDOWS\PMSDK.ini Error number: 0x80004005
I will appreciate if I get solution to the issue or at least PMSDK.ini file from someone. File is usually located here C:\Windows
Z
Z
here you go
[Application]
SubSuite=E
AppType=orion
Suite=P3E
LastUserName=admin
CommonPath=
ApplicationType=ERPM
SuiteType=P3E
[CustomConfiguration]
appoptionspath=C:\Program Files (x86)\Common Files\Primavera Common\
configfile=
configpath=C:\Program Files (x86)\Common Files\Primavera Common\
appoptions=SuiteInfo2.xml
Z
zyoxizol Gajjar 👤 Member for 11 years 2 months
Hi Zoltan,
Appreciate your reply.
I checked my C:\Program Files (x86)\Common Files\Primavera Common\PMSDK\Engines but can't find any .INI files there as well as nothing under C:\Windows.
The only reason I thought file was under C:\Windows because I got this error which logged that file was missing from that location.
“”Row 0: RDA error: Resource not available - Connect error: da=PMSDK;Driver=PMSDK;engine=PM;lf=C:\temp\PMSDK.LOG;lo=terse;pg=1;pp=privuser;pu=privuser;.
Error number: 0x80004005”
Anyway, is there any chance of getting my hands on your PMSDK.INI file or what is written in it? It will be a great help if you can post what is written in it as .INI files are only text document (need admin access though).
Thanks again Zoltan (the original Z :) )
Z
Z
Hi Zoltan,
Z
Z
The default location of the SDK INI file is C:\Program Files\Common Files\Primavera Common\PMSDK\Engines\PMSDK.INI
However mine is located in C:\Program Files (x86)\Common Files\Primavera Common\PMSDK\Engines
NOT C:\Windows
The Original "Z"
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
GeoVe
Johannes Vandenberg
Soheil Barekat
Peter Holroyd
Neil Atkinson
