P6.1 SQL error
Trying to speed up P6.1 with SQL commands.
When I try to enter:
1st Query
update statistics project with fullscan ,all
update statistics task with fullscan, all
2nd Query
exec sp_updatestats
I get error:
Msg 2706, Level 16, State 6, Line 1
Table 'project' does not exist.
L
Leo Nicholson 👤 Member for 20 years 3 months
It has been awhile, but I had to install P6.1 on a new laptop.  Windows 7 Pro 32bit.  It installed and runs ok, but when I try to run the SQL tweaks:
1st Query
2nd Query
exec sp_updatestats
I get the following:
[[wysiwyg_imageupload:2445:]]
L
THANK YOU for taking the time to address my problem.  Your first option exactly addressed my problem.  Load time literally went from 30 minutes to about 30 seconds!
I really appreciate your help.
Leo
S
Steve Ellis 👤 Member for 20 years 3 months
Hi Leo,
From what you are explaining, it sounds like you are using SQL Server Management Studio to run the queries. Please advise if this is not the case.
When you run these queries you need to ensure that you have your P6 database selected. There are a couple of ways you can do this.
The first is to ensure that the drop down box at the top left of the screen has your p6 database selected. I'm assuming this is probably displaying 'master' for you. it should display something like 'PMDB' or 'pmdb$primavera'.
[[wysiwyg_imageupload:1732:]]
the second option is to specify a command as part of your query. eg. if your p6 database name in PMDB you might run the following:
use pmdb
use pmdb
exec sp_updatestats
Please note that updating your database statistics is not a golden bullet. There may be other issues causing your p6 environment to perform slowly.
Stevel
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
