Can i make my Project plan on days only and not actual dates?
Good day everyone!
I have, what i hope, is a simple problem. I constantl create plans for construction projects, that might not start on the predicted day i would like it to start on.
I assume, that if i plan in automatic mode, i should only have to change the start dated, and automatic mode will automatically change all the dates.
But..sometimes i would just like to make my construction plans on numbered days only and not actual calender days. If my project is planned for 120 days, i would like to have the option to view it in days 1,2,3....118, 119, 120
Are these things possible??
Thank you!!
Robert Bell 👤 Member for 10 years
Hi Timothy,
You can find this by right clicking on the top of your Gantt chart; hover over the timescale itself, right click, and then click on "Timescale".
Hope this helps.
Rob
T
Timothy Reducha 👤 Member for 10 years 7 months
Thank you Robert;
You can show ordinal dates on your Gantt chart by changing the units of time in the Timescale options to "Days" and then changing the label to "01, 02, ...."
Where do i click or find the timescale options to days,,in ms project 2013?
Hi Timothy,
I'm not sure if you can do it with the date fields though. You could use the "3/W05" date format in the General tab of Options, it's kind of ordinal but not the best format.....
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
