Project Overview
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
MSP variance is ok.
we can use formula to calculate variance to our requirements(whatever may be the baseline).
Gary & Samer,
it is not possible in MS Project to select a specific baseline as the "default baseline" against which MSP would compare "Actual" to calculate a Variance.
Project overviews Variance is always calculated between Actual Start / Finish and Baseline Start / Finish; where "Baseline" stands for "Initial Baseline" with no number (i.e. <> "Baseline1", ...
if you want to save a 2nd baseline and have it used in the Variance, you will have to save "Baseline" as "Baseline1" first, then save the current project as "Initial Baseline (no number)" again
Alexandre
Dear Gary,
The variance is between any two schedules that you select.
With kind regards,
Samer
