Liquidated Damages
9 replies [Last post]
Samagata Chakravorty
User offline. Last seen 9 years 17 weeks ago. Offline
can any one comment on the following,
if the contractor delays completion but no effective non-completion certificate is issued by the architect/engineer under a JCT contract,will this mean that the employer loses the right to deduct liquidated damages?
regards
Sam
ashraf alawady
User offline. Last seen 10 years 50 weeks ago. Offline
In UAE ,we are using the general condition of contract which almost has ben extracted from FIDIC.
we have never used JCT.
Thax Andrew for ur valued comments.
sam
Andrew Flowerdew
User offline. Last seen 3 years 44 weeks ago. Offline
It does depend on what version of the JCT contract you are working on though - I’m assuming it’s 1980 or later.
Andrew Flowerdew
Samagata,
Both the issue of a certificate and a request made in writing by the employer to deduct liquidated damages, are condition precedents to the Employer deducting liquidated damages.
A certificate of non completion can not be issued after issue of the final certificate and so if not issued before the final certificate, the employer will lose his rights to liquidated damages.
ashraf alawady
The client can not lost his right due to non issuance of ’no effective non-completion certificate’ .
As per the contract the only certificate which can prove that the contractor has completed the woke and maintane it properly is the maintanace certificate.
That mean even the issuance of taking over certificate can not hold the client right to deduct the liquidqted dameges at any time befre issuing maintanace certificate.
Non issuance of ’ non-completion certificate’can not consider as basis for any contractual issues .
Larry Bjorn
User offline. Last seen 12 years 46 weeks ago. Offline
Sam,
Can a non-completion certificate be backdated?
Larry
hi akhilesh,
JCT stands for Joint Contracts Tribunal. its a Standard form of Construction Contract like FIDIC.
sam
Oliver Johnstone
User offline. Last seen 14 years 36 weeks ago. Offline
Yes
Akhilesh Shukla, ...
User offline. Last seen 5 years 43 weeks ago. Offline
Groups: GPC Qatar
Hi Sam
[English only, please - The Moderator]
Wht’s JCT contract?
Akhilesh Shukla
