Currency format
Hi Pplanners and PP users,
When I export a PP project as an XER file, the Currency thousand separator field remains empty; as a result, P6 does not want to import the project; I have to open the XER file in MS Excel, fill in the field and so on.
I have not found yet where to set up the thousand separator in Powerproject, it would help a lot.
By the way, many thanks to Malcolm Emmerson for his webinar earlier this week, very good!
Alexandre
B
Ben Taunt 👤 Member for 14 years 5 months
Hi Alexandre,
As per my last, please make sure the Windows Regional Settings match the format that you need for importing to P6.  Sounds like you have a space in the settings, which is why the data is coming out without a different seperator.
It's probably best to contact either us or APP direct with questions like this, as we can then put all the correct resources behind answering your questions in a timely manner.
Ben
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Ben,
I am working with Powerproject 15, translated in French by the spanish reseller and myself
The currency settings int he Export dialog only allows to select on currency in the list; I see nowhere how to set-up the separators.
In the Options dialogs, I have seen that the thousan separator for cost/revenues is a space, and the decimal a dot; in the Windows Regional settings for France, they are respectively a space and a comma.
Thank you for your help
Alexandre
Ben,
Alexandre
B
Hi Alexandre,
I passed on your thanks to Malcolm and asked him to look into this one for us!  He thinks it is a Windows setting and a P6 setting.  Powerproject adheres to Windows currency separators and there is also a currency setting in the XER export wizard in Powerproject that should match the equivilant P6 setting.
Please do email Malcolm for more details.
Best wishes,
Ben @ Powerproject
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
