Fonts and Formatting
Dominic Planner
User offline. Last seen 1 year 51 weeks ago. Offline
Greetings Planners, my first post so be gentle.
I have inherited a programme and I am unable to increase the fonts in each subheading that's been created. I have successfully managed to change all the other fonts in the activities and other headings but these are stuck at 5. This makes them to small to read when I print the programme off. I have tried using the fonts on the 'Home' tab to no avail, likewise using the 'Default Table Fonts' in the Format tab. Both of which weren't of any use.
Any advice is appreciated.
Dom
Dominic Planner
Ben,
Many thanks for your response, I have managed to amend them that way.
Thank You
Dom
Ben Taunt
User offline. Last seen 1 year 47 weeks ago. Offline
Hi Dom,
If your programme has 'heirachy' to it (i.e. a number of summaries or expanded tasks), fonts and cell colours can be set at a heirachy level to help you clearly display the various levels.  Therefore, these settings may be overriding your table defaults.
Check 'Hierachy Appearance' from the 'Format' ribbon to see what these are set to for each level of the programme.
If that doesn't help, feel free to contact our support team via support@elecosoft.com.
Ben @ Asta Powerproject
User offline. Last seen 47 weeks 3 days ago. Offline
Hi Dominic - Welcome to planning planet.
Right Click on the column you wish to change.
Select Format cells - Select the Font dialogue - make your selection.
