Oracle Primavera - PM6
Description
Here's a place to discuss some Primavera Enterprise questions
Container
No
Import Relationships
S
sam dsoza 👤 Member for 20 years
I want to import realtionships from a P6 file 1 (correct relationships) in to a different P6 file 2 (incorrect relationships).
Doing it manually is possible but highly time consuming as I may have to touch 700+ activities.
Importing relationship data from correct P6 file in to incorrect one should be POSSIBLE but I have not set up the import file in a while so not sure whats the best route.
Any pointers in this direction will be appreciated. If there is a post which has already addressed this then please point me over as I could not find a topic addressing my needs
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Assigning Updated Schedule (Has actuals) as Baseline
Dears,
I have a issue while assigning the current schedule as baseline which has actuals already.
I have already changed the Planned Start=Start and Planned Finish=Finish.It works fine for Non started and Completed Activities.
But for all in progress activities i have an issue.Schedule % is not matching with the performance %. Could any one suggest solution on this regards please.
Not Activity % completion type is :Physical % Completion
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Dears,
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
P6 did no automatic re-calculate Date when update schedule
Dzung Dong 👤 Member for 10 years 7 months
Dear all,
I'm newbie in group. I have a problem when update Schedule in Primavera as below. Hope get your clarification, instruction:
* When i update activity in P6 by manual follow these steps:
- Step 1: Create Baseline
- Step 2: Update activity (Depending on report, I updated each activity), i met problem, example with Activity A:
+ In Status Tab (Belong to Activity Detail option): Check started (Actual Started Date = Baseline + 2 days)
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Unable to copy P6 Schedule
Ron Liu 👤 Member for 9 years 4 months
Hello,
I have a schedule in P6 EPS that cannot be copied or make reflection. I can copy or make reflection of other schedules. I check all the settings of that particular schedule but they are the same as other schedules. Does anyone know why or experience it before?
My P6 version is 15.2.13.
Thank you.
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Convert Microsoft Project to WORKING .xer File
Hello All,
I am trying to import a microsoft project file to Primavera P6 version 7.0.
I have done this in the following order:
1. open project file using asta and then save as an xer file (it opens fine is Asta with all logic and WBS correct)
2. import to P6 in the normal imort method for an xer file however the import loses some links and activities are no longer in their correct WBS. All the activities, links and WBS are present but the activities are no longer in the correct WBS, all are under one new WBS that the import seems to have created
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Close an unfinished project in Primavera P6
M
Maxim Dr 👤 Member for 8 years 10 months
Hello, I am trying to close a pfoject in Primavera P6, which has not been completed but has to be closed untimely.
Some activities, which had been planned earlied and which were going to start in the future, never started.
How do I properly close it in Primavera P6?
For example, today is 25 July 2017. Activity A is the latest activity and is planned to start on 1 January 2018 and finish on 1 January 2020.
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
