Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
Calculation of budgeted units in prima vera
Ahmad uzair 👤 Member for 13 years 2 months
Hi all,
I have a building project in prima vera Orcale R8.1. I have resources of labour,Mason,Steel fixer.I know their average consumption per hour like for example,labour takes 3cft/hr for excavation.
My problem is that how do implement this data in my resources ? if my area to excavate is 500cft then my duration will be 20 days (8 hr/day). Now what will be my budgeted units and planned units in this
Please help me.
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Primavera V8.4 Out of Bounds error
I am trying to link 2 simple activities together on a straight "FS" relationship, the problem I am getting is that the following error comes up. I have tried copying the program, Export / Import, and even delete / re-create the activities (which are in different WBS's), but still have the same issue with these two activities. Is anyone able to explain it, as a lot of the other re-sequencing I have done around them has worked successfully.
Type:            EListError
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Productivity Rate for construction activities
Hi All,
I looking for a productivity rate I can use for Project Planning like for Concrete volume in cu meter - how many workers required and manhour requirement for formworks, rebar installation and concrete casting.
Can anyone help me.
Thanks.
Vincent.
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
New Tasks With '0' Float Throughout the Schedule
I am trying to create a test schedule in MS Project 2010.  The problem is that with every new task that I create, there is no float associated with the tasks being entered.  I have tried the following:
1. Moved the Project Start date out six months or more
2. Ensured all of the tasks were linked
3. Added a Deadline Date for the last tasks in the Network
4. Changed all Constraint Types to ASAP
No matter what I have done, there has been minimum to no float in this test schedule.  Can someone tell me what I"m missing on this?
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Problem to make Recovery Plan as a new Baseline
Hi Guys,
I prepare a recovery plan from last updated program, i was monitoring the progress based on total Budgeted Cost and all activities were Phisical % type. My project was in delay due to our mistake so i adjust the remaining duration by increasing the productivity and changing some logic. Now i want to use this as a new baseline so which values i have to use. Remaining total Cost or Budgeted total Cost as Planned Value?
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
