Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
Concrete Pours
V
Vrinda M 👤 Member for 18 years
Dear all,
As you have been helping everbody with construction & planning techniques please advise in a project if we have basement area - 3300 sqm. how should we plan for concrete pours.what should be basis for concrete pours??how this sequence should be preferred.also if i have plot graph for concrete each month then for each day how much concrete is pumped/poured.please give a detail understanding on this case.
Rgds,
Vrinda.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Schedule Logs
Dear fellow planners,
I would like to get your background on how you are using "Schedule logs" created after calculation.
I mean, there is a lot of interesting information in it like errors or warnings (Activities w/o pred, w/o succ, with invalid relationship,...).
Firstly, this is a good report to clean some hidden mistakes but:
- Do you use it for other purpose (like claim, internal analyse,...) ?
- Do you compare rate of relationship Qty to Activities ? What is telling you that a schedule is not linked or too much ?
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Negative float in P6
Sir
I have a problem with displaying negative floats in my project during progress updation. I have put a must finish contraint to the activities. But activities whose actual start and actual finish are entered does not display negative float, though its supposed to be showing a negative float. Plz help :)
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Milestones and Key dates WBS
Hi Knowledgeable professionals,
Please should all milestones be gathered under a unique WBS (e.g. a WBS named "Milestones and Keydates") or should it be inserted within the WBS containing the deliverable that is related to the milestones (e.g. Engineering milestones should be under "Engineering WBS", MEP milestones under "MEP works" WBS).
Thanks in advance for your valuable help.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Integrate P6 with Esimate
Rob Kane 👤 Member for 22 years 5 months
Hi Guys,
Has anyone out there had any experience with integrating the schedule with the estimate.
My organisation currently works with an estimating depatment that goes off and builds an estimate (they use expert & or Candy) at the same time we have the planners building a project schedule in P6.
We dont currently have a system to integrate the two sources of data.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Schedule Review Meetings
M
Miguel Rios 👤 Member for 16 years 8 months
The client is organizing a bi-weekly Schedule Review Meeting. The proposed invitees are the planner, the project controls manager, and the project manager from the client side. On our side, we have the project manager, the project controls manager, the engineering leads, the procurement manager, the construction manager, and myself. No agenda has been indicated yet. The time slot is 1 hour.
What would be an appropriate agenda for this kind of meetings? What should be the topics discussed? What is the recommended time slot for each topic?
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
SIMOPS Planning
I find it very difficult to plan the SIMOPS into the schedule. Say you have a limited work area and you have hi-pressure activities such as leak tests in that area. When you do the leak tests, all other activities must stop.
What I have done is to mark the hi-pressure activities in a special code and try to push away or bring forward the non-hi pressure activities such that they don't coincide with the hi pressure activities.
Doing this by using predecessors is very time-consuming.
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
SIMOPS Planning
Soheil Barekat
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
