Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
Resource loading for multi-level structure with non-typical floors
Hi Guys,
How do you usually do this.
We will build a 3 levels podium RC structure with 2 basement, so over all 5 levels. Each level has a different wall layout plan & floor framing plan, so there will be no levels with the same quantity of material resources. Contruction programme was made, just a typical construction programme, start from lowest level going to upper levels. And also, each level was divided into bays to determine concrete pouring sequence. It is like this:
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Productivity and Norms
T
TII WS 👤 Member for 16 years 4 months
Need some assistance in buildig up the as built productivity.
I was thinking of classifying under such category as below
Excavation
Bored pile
Pilecap
Raft Slab
Ground beam
Column
Slab
Any idea what unit should I use if I were to build this in relation to resource usage as well. Should I use qty/day, or manday/qty or any other suitable unit ?
Any idea to improve on these? Or should I split further into rebar, formwork, etc
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Rough Estimate for 1 Residential Building 1 Electrician / floor
Dura Cell 👤 Member for 15 years 6 months
Dear All,
For those experience planners, is it possible for 1 electrician + labor / floor to work on residential bldg?
I am working on rough estimate of manhours on site.
Thanks PP members
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Addition/deletion of activities and relationship changes to updates to an approved programme under NEC3
Does anyone know of any provisions for projects managed under NEC3 regarding addition/deletion of activities and relationship changes to an approved programme?
Is there an obligation on the contractor to provide list of added/deleted activities, relationships changed and reasons why?
Thanks.
E.
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Transferring of Activity Progress
Im having problems on importing activity progress from my "Progress File" to my "Working File". I've tried doing the "P6 to Excel to P6" importing/exporting method.
In the process of exporting my "Progress File" to excel, I called out "Activity % Complete" as part of my excel template. Then, it reflected as "(*) Activty % Complete (%)" on the excel spreadsheet.
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Project tracking - Updating in MPP 2003
I need help for project update,
I have a master schedule of 1350 activities with only task's (no resources and cost) I have saved baseline and inserted column
of Baseline duration and baseline start and finish, and also inserted actual duration and actual start and finish columns and
%age complete for tracking, I m updating actual data like %age complete inserting in activities and start date and finish date as per actual progress.
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
Urgent help - Project extraction from baseline
S
siva ganesh 👤 Member for 14 years 6 months
Hello friends,
I have a initial project. And another one i have an updated project.
Now what i did is, in the initial project i added baseline from the option "convert the other project as baseline" and i assigned the updated project as a new baseline.
Unfortunately i deleted the updated project.
Now is there any possible way to extract the updated project which is assigned as baseline 1 to initial project?
Hope u understood my problem.
Kindly help with a way and advise.
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
MSP resource tracking problem, help needed.
B
Bogdan Dinu 👤 Member for 13 years 9 months
Alright,
so I have this new project that started with the planning pretty late so we needed a project plan quickly.
They wanted to track the plan before we got the real resources inplace so I used a fake resource with 2500%.
My problem is,
Exampel at status date:
Act: Build wall | Duration: 32 d | Work: 32 h | Act Work: 0 h | Rem Work: 0 h
Then my projectleader tells me that we already worked 32 hours but we need another 100 to finish the work,
and we still want to finish on 32 days.
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
