Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
K Factor in Progress Measurement System
S
Siddic K 👤 Member for 14 years 8 months
Dear All,
1. What does "K" factor mean.?
2. How to calculate and fix K factor for a project.?
I handled few projects with progress measurement system. Some of them use 0.8 and some of using 0.6, which is one correct or it will differ always based on project nature.?
Please explain me.
best regards
Siddic k
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Computing Critical Path Drag in Start-to-start (SS) Relationships
There is a Wikipedia page that explains how to compute critical path drag, but only with finish-to-start relationships. I recently had a long discussion with another PP member, Dennis Hanks, in which I mentioned the value/importance of computing critical path drag and drag cost. Dennis looked at the page and indicated that the concept seemed not that valuable as drag "is confined to networks with only FS relationships!"
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Activities Finish Dates
A schedule was built completely by my colleague, and after it was sent to the owner for approval, It was requested to modify it and divide all activities to more detailed ones with maximum duration 21 day.
I started to modify and divide these activities and merge some electromechanical items in the schedule, but I noticed that the finish dates for most activities when I run the schedule changed and pushed one day.
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
S Curve for cost and Manpower both shows different
Dear All,
I have a situation.
as this week i update the program total performance complete is more than scheduled but when i prepared cost based S curve the actual value for this month is coming less than planned for the month (if i go through budgeted and actual manpower it is showing logically  correct values) please help
scenario
my project is divided in two segments
Villa and Infra
 villa is ahead of Scheduled with positive float
Infra is behind the scheduled with negative float
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Why Must Finish By Constraint causes Late Finish to complete earlier than Early Finish?
Helllo,
I have the must finish by date on the project set to Oct 12 2015.  But why would the late finish date be earlier than the ealry finish date? I understand the negative float is due to the project being behind. See snapshot below. capture.png
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Software for fast "visual" programme
Good morning everybody!
Just a quick question probably for some of you:
Is there any free software I can use to create fast and clear small programme with the pourpouse of rapresentation/comparison of programme?
I try to explain it better:
Sometimes I would need to prepare fast "summary programme" in order to compare easily some specific task or to create small sub-programme which contains activities at level of detail not required in Primavera main programme.
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
