Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
When to rebaseline a schedule
Hi. I would like to know when is the best time to rebaseline a schedule. Is there a standard variance value that should be considered or is it different with each schedule? If it is different for each schedule what is the best approach to deciding this, e.g. do we set the variance limit at the planning phase?
Any contribution on how you do it or how you think it should be done is highly welcomed.
Modelling men and material logistics
Hi all,
Working on a concentrator build, greenfields next to brownfileds environment. Need to model the men and material flow to optimise bottlenecks, security turnstiles, change houses etc. as well as the way the laydown yard is set-out with required material flowing to construction areas optimally.
Looking for companies and/or software packages working in this sapce. Based in South Africa.
Morne
Msc Construction Project Management Dissertation Topic Feedback
M
Mark Kane 👤 Member for 14 years 8 months
Hi All, I am trying to come up with a research question and general areas of study within planning and scheduling.  They are as follows:
  • To examine criticism of planning tools (primavera, MS project, Astra, full Project Management tools), traditional techniques (CPM, Earned Value) and the failings of planning as a discipline.
  • To examine attempts at improving planning and scheduling techniques (Lean Construction, Critical Chain, 4D BIM etc)
  • To find out if Project planning and scheduling, progress reporting techniques
4d planning software
Does anyone know how I can get a trial license of Synchro Pro? The webiste says the demo is only a 15min screen sharing session. I wanted to have a go myself to see how easy it is to use and what I can do on it.
Ive been using Powerproject BIM and trying to import from Sketchup but its rife with problems and I dont seem to be getting the model that I want.
Apart from these two are there any others that would be worth trialling?
