Asta Powerproject
Description
Discussion on aspects of Asta Powerproject
Container
No
Filter Appearance with heirarchy appearance
Hi Guys,
I have created a few filters and coloured my wbs structure using the heirarchy appearance.
However, when I apply a filter, my heirachy appearance structure doesn't follow through with the filter. Rather it becomes a spreadsheet list of what my filter has found without the colour.
Any idea on how i can set this up on filters?
Thank you in advance.
Farhad
Column drop down list for codes
Hi All
This is my first post! I am fairly new to ASTA and have come across a few interesting things that P6 doesn't have!
When adding a coded column, how would i add a drop down list to the fields?
Rather than having to drag from the code library from the left hand side to the Gants chart bars.
Hope the above query is clear.
Thank you for your help in advance guys!
Show Hammock allocation in a column at task level?
Hello,
I have a project on Asta that uses hammock tasks to summarise packages of work. I've been searching for a way to add a column that shows what hammock a task is assigned to; does anybody know if this is possible?
Any feedback would be greatly appreciated.
Rich
Importing XML file into Asta
amir azadi 👤 Member for 14 years 2 months
i tried to import a  XML file to Asta, for some reason Asta Split  whatever task longer than 4 days into  several new tasks and roll it up under one task. Is there any way that i can stop this, is there any option in Asta that limits the maximum duration of one Activity?
With Thanks
asta power project
T
Tolga Taluy 👤 Member for 10 years 11 months
Good morning All,
I am trying to establish a KPI graph based on weekly activity count of the programme to display the progress of the project.
All I can do is resource the project and and create a histogram based on all resources and export the data to excel.
But I am sure there is another way (way easier and less time consuming) to reach weekly activity counts data and export to excel. I appreciate any  feed back may help.
Regards.
