Part days of float
P
Paul Harris 👤 Member for 25 years 2 months
There are many reasons why this may happen, but displaying the times with the date is the first step to resolving what is happening.
Then as Brian has indicated check that you default start and finish times are aligned with your calendars.
Paul E Harris
www.eh.com.au
B
Brian Ultican 👤 Member for 19 years
Go into Tools | Options | View and pick a date format that shows the time.
It is possible that the Finish date of the task in question as a time on it that is not the same as the default end time for the calendar.
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Stuart,
1. did you put a date constraint on one task?
2. did you change something in the calendars or calendar options?
Alexandre
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
