Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
S curve Formula
B
bryc ali 👤 Member for 16 years 7 months
During my experience in few company, I found a kind of table to draw our s-curve, you can choose a number of period and you have the forcast corresponding of this period, the periode can be (hour, day, week or month), for exemple :
Number of period 4 / period( 1) 13.20% / period( 2) 27.50% / period(3) 36.40% / period(4)  22.90%
With this value you can draw your s-curve, DO you have any information about it ? or the function that you can insert only the number of period and you have the percent that you mus achieve in each period ?
Remaining Late Unit tabulated based on Early Finish Date
Hi.
Basically the situation is I need to do a revise programme, so I used the latest updated schedule, revise and re-baseline it. So from the revised programme, I input new resources as I need to generate S-Curve with 3 main elements which are Planned Early Finish, Planned Late Finish and Actual. I used  resource assignment then paste the tabulation in excel.
Historical Data of Projects
I would like to seek the expert advice here as to what sort of historical data a planner should have readily on hand by the end of a project, to better prepare for the next one.
This would include things like Scope / Rates / Costs.
Are there any other items which I should take note of?
Benjamin
Developing Schedule for Construction of Cement plant using Primavera P6
I am Student and I am currently Project management course we are required to obtain data of a chemical plant and perform both time and cost management so I used the data from the link below
http://c-pmt.weebly.com/uploads/4/0/1/7/4017805/final_assignment_sample…
Terminal Float - Increase in Duration
Dear All Planning Planet Users,
I understand that the contractor own the Terminal Float and I understand that if there was a compensation event that impact the planned completion date, the contract completion date will be impacted by the same amount of time. but if the planned completion has been brought forward due to combination of efficient working and client giving access early etc, can the Terminal Float be extended?
