Planning, Scheduling & Programming Discussion
Description
General planning comments and questions.
Container
No
Primavera P6 Exercise
M
Merty Mac 👤 Member for 3 years 1 month
Hi All,
I have an exercise that is set around manufacturing (not experienced in Manufacturing) and has a requirement to produce, say, 6 laptops. Each unit is identical in terms of process, i.e. Procure materials, manufacture & assembly, Inspection & testing, then acceptance.
Question: Would you generally create the schedule for unit/laptop 1 then copy & paste activities  into seperate WBS elements, Unit 2, 3, etc. or just create a simple Unit 2-6 with a start/finish date rather than detailing all remaining units?
Estimating Updates
Over the last couple of weeks, we have been updating the estimating pages on our website, partly in response to the #NoEstimating idiocy. There is no way an organization that intends to survive will undertake future work without an idea of the required resources, time, and cost needed to achieve the objective and an understanding of the anticipated benefits – this is an elementary aspect of governance, which requires estimating! BUT there are two distinctly different approaches to estimating software development and maintenance:
Using what you know now in prior period updates - acceptable?
A procurement item is discovered to be taking 90 days longer than expected, you discovered this in March but you are updating February data.  You could and should revised that duration to add 90 cal. days, otherwise you are publishing knowingly wrong data.  Plus this did not happen in March - you don't when the equipment vendor started sand-bagging - probably from the start, so either way you should use the data you know now (not then) as correct for item?  correct?
Is it "a thing"? that GCs like to kick small subs off because they like to spend that subs bond money = more that way.
s it "a thing"? that GCs like to kick small subs off because they like to spend that subs bond money = more that way. It seems like I have seen that enough to make me suspicious = kicked off due to schedule, usually.  Seems mainly on private jobs, not public.
Earned Schedule 20th Anniversary Celebrations
We have supported two initiatives focused on celebrating the 20th anniversary of the launch of Earned Schedule in 2003. Earned Schedule (ES) resolved the long-standing dilemma of the EVM schedule indicators providing inaccurate information for late performing projects. ES provides the ability to predict project completion dates with more accuracy than CPM. It uses the same data as traditional EVM, but shifts the calculations from the cost axis to the time axis.
Best system to connect CPM sched with Submittal log with SOV (sched of values) ? - essential but difficult
Best system to connect CPM sched with Submittal log with SOV (sched of values) ? - essential but difficult.   With the increase in data systems, there has been an increase in non-essentials getting in the way of essentials.  More work, less hours per task.
