Oracle Primavera - PM6
Description
Here's a place to discuss some Primavera Enterprise questions
Container
No
What is the easy way to move an activity from lower level of WBS
I have received a Pre-Comm/Comm schedule from our contractor , now my management wants me to add remaining construction activities to this schedule to drive mechanical completion , So I added Sub WBS to the existing WBS. There are more than 1000 activities which needs to be moved to the next lower level.
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Group Interval
P
Paul Kral 👤 Member for 8 years 9 months
Hello,
Can anyone tell me whether the date notation - in grouping bands - can be changed to European date format?
I've grouped my layout on 'Start' and defined the Group Interval as Day.
[[wysiwyg_imageupload:4997:height=200,width=300]]The Grouping bands present the date in following format: "Ddd MM/DD".
Whereas my User Preferences have a different format (also visibile in Start and Finish columns).
[[wysiwyg_imageupload:4999:height=307,width=300]]
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Earned Value Cost vs Physical Percent Complete
Hi, how could i solve my problem on how to correct my earned value cost calculation on my updated Schedule in P6. Example of incorrect earned value cost is 2500USD instead of 6500USD at 100% Physical % Completed. Is there any way to resolve this issue? Is there any settings needs to fix in P6 v8.2?   Thank you in advance.
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Turn around Planning and Scheduling
V
Viet Tran 👤 Member for 9 years 3 months
Hi everyone,
Can you sharing or providing me and somebody else  your experience/information about Refinery/Plant Turnaround/Outage using Premavera P6? I have experience my first turnaround scheduling using P6 but I think I have so many thinks to work and improve my ability, such as how to manage from plan phase to exection, to prgress report, to construct the WBS, resource levelling, ..
Thanks you all,
Viet Tran,
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
P6 Professional 16.1 will not add new pred or succ in Window but will using highlight and button combo
J
John Reeves 👤 Member for 13 years 1 month
P6 Professional 16.1 will not add new pred or succ in Window but will using highlight and button combo.  It is almost as if something is keeping the add activity window from popping up.  I will pop up if I click an existing predecessor and change it but will not if there are no predecessors.  Same with successors.  I can work around not being able to just simple add a new predecessor by just using the activity above it using highlighting and the top ribbon button and then change it - but I assume this is a bug or something.
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
