WBS
Greetings Planners,
I would like to print out on pdf WBS but it is a bit big one, when I fit it to one page it can not be read
regards,
muataz
- Read more about WBS
- 8 comments
- Log in or register to post comments
Here's a place to discuss some Primavera Enterprise questions
Greetings Planners,
regards,
muataz
Greetings Planners,
I am exporting project to excel from P6, the project includes 4 levels of WBS and when I export the project to Excel, it considers only the last level, how can I show all levels in Excel?
regards,
Muataz
Oracle, at the very end of 2020, released Primavera P6 Professional 20.12. Here's what's in it https://ed.gr/c38ud
This report writer is very tricky. When you try to save a copy to make changes, the copy is not the same - very odd. Also, I am trying to do is modifying the detail pred succ report so sort by WBS, then early finish. When I add a top row & tell it to sort by WBS the fields turn red meaning they will be deleted. Why is that? Any tips? This report has an activity with information and then under it detail lines of pred then succ. At first I saw the the titles and variable fields for the first line. But now I can not see it but it still prints
Gents,
After making an excel file export from the schedule, I have tried to import again to the same schedule.
However, when I reached the step at which I should select the project to import for, the screen was empty and didn't give any project to select. Hence, I have tried to do the import from a different user account and to the same project and didnt face this issue, and the issue appeared only at my user account.
I have created a view which has two levels of activity codes - Example (for illustration only) level 1: Building and level 2: Work Type. This is not the WBS. Using grouping and sort I selected the two levels and checked the box to "show summaries only". When I view the result I am looking at the summary bars at Work Type level for each building.
hello
I have an activity showing a cost variance in the variance column even though that activity does not have a budgeted total cost.
Please help, it has to be a setting issue i think....
OK - I figured this one out, sometimes posting the problem helps, kept here for others: I told it to print portrait & it it printed is landscape - solved. What-ever works, I don't ned to know why. This was the problem: Time scaled logic diagram - all setting on Landscape still prints portrait? I am running it in citrix which likely has something to do with it. I am printing it to D size, does it matter if ansi or arch? This type of print was moved to the Visualizer product. I have said bad things about visualizer - but the controls on the TSLD a
I am trying to export Period Performance $ Values from Excel from one project and import to anothe rporject in same database. (common Periods) basically trying to import for all activities but whichever I import it does not update; I exported and used same template to import after updating periods values and not working. Is there a trick to this, so lost...
