Global Change
M
Mahsa Sajadi 👤 Member for 16 years
Hi Rodel,
Great Thanks! Great Idea. No resource has been defined yet. I’ll just should store the actuals right now.
Mahsa,
If you remove one resource to activity then actual unit will be gone. If an activity has more than one resource assigned it will not transfer actual unit to another resource when removed. If only one or two activities then manually edit actual, budget and remaining unit before deleting the resource. If many activities involved then store resource data (i.e. budget, actual and remaining) on resource intended to delete on UDF then use global change to add it on another resource.
M
Hi all,
a new problem! in the middle of some activities, I just want to remove one resource but maintainig his actual units, possible?
I’m thinking of changing the budgeted unit or remaining unit or ...
M
Hi Rodel,
That’s a great idea. i’ll apply a filter for the activities I want and then go through it!
Kind Regards
Masha,
You cannot use global change to add new resource but you can select all activities that require new resource and assign all at once.
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
