Reference Planning Projects
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Hi Shiva
Everything depends on your scope of work.
Are you also doing the M&E?
The main interfaces for fit out are:
1. Weathertight.
2. M&E Carcassing - Floors and Ceilings
3. M&E 2nd fix - Floors and Ceilings
4. M&E Commissioning
Common areas and washrooms are a standalone subject and are always a problem - make sure these are planned in detail.
Look out for shared acces routes and trade occupancy at each level.
Rubbish disopsal and hoist time have to be considered.
Other than that it is quite simple.
hi samer,
thanks for ur information. actually, we are the subcontractor for the interior & fitout works in a high rise building (upto level 41). As i am a beginner to this field, I have to prepare the baseline program from the main contractors construction program. so, could u pls assist me in-detailed about the sequences, milestone dates, constraints.
and what are the important things to be considered to prepare the baseline program. while updating, what are the points to be followed with main contractor in order to avoid any delays from our side.
thanks... samer..
shiva
Dear Shiva,
Tell us a small description about the actual project that you are working on and we will try to assist as much as possible.
I would also recommend that you read the information at the following site. It will benefit you greatly.
pmbook.ce.cmu.edu/09_Construction_Planning.html
With best regards,
Samer
Hi Mike,
Thanks for your reply..
Yes, you are correct.. Just i would like to compare the sequences which i have followed with the others.. thats why.. if u have any type of project for high rise building, pls. mail me to [email protected]
Thanks.
shiva
Hi Shiva
All projects are different and you have to work out your own sequences on each new project.
If you cant build then then you cant plan it.
Good Luck
