P6 % Display problem
Maybe by clicking desired column and selecting format you could get what you want, similar to Spider Project where you can save on your layouts different formats for the same column. As you can see Duration Days for Layout E is shown rounded to one decimal place while in Layout C it is shown rounded to five decimal places. In both layouts Start is shown down to the minute while Finish is shown to the second.  Because for this sample schedule 9.375 days at 8 h/d equals 75 hours so we do not see fractional hours.  I suspect you are looking in the wrong place. Similar to Excel where you can format your cells.
layout-column-formats-01
layout-column-formats-02
format-column-01  format-column-02
J
John Reeves 👤 Member for 13 years 1 month
I tried to follow the "settings" to round the Activity % complete to 0, I could not find it.  I did not see the settings referenced.  I am not going to set up a udf, the pct complete to 2 decimal points is crazy.
Z
edit user preferences dates tab units format 0 decimal places durations format 0 decimals or admin preferences custom % complete 0 decimals
J
Is this corrected in the latest version of P6?  I thought I read that it was but I cannot figure out how to get it off the two decimal reading...yes, the UDF device will work.  Come on Oracle, it has been 15 years and P6 still cannot do basic formatting that we could do in P3.
B
Beau Wolfe 👤 Member for 10 years 7 months
Arnold,
Can you elaborate on the steps you listed above? I didn't have any luck trying to follow you.
Beau
David Kelly 👤 Member for 21 years 7 months
I have used P5/P6 since its introduction. I do not know how to do this. I agree that showing percent complete to two decimal places makes no sense to any planner. But this is a cost planning system, and the cost engineers like decimal places.
Arnold Puy 👤 Member for 19 years 1 month
Hi Mohammad,
Create a UDF say, %Comp and the Data Type is "Integer".
Then create a global and rename. Select Subject Area "Activities".
Then:
%Comp = Physical % Complete
Note:
The Percent Complete is depend on what you are using whether Physical, Duration, Units or Performance % Complete.
Arnold
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
