Project and Resource calendars
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Hi Mike
Whatever software you use if you put a different calendar on a resource to that of the task you will get bizarre results.
If you have the facility tick your resource to follow "calendar as task" and you will have no further problems - even when you change the task calendar.
As Dieter syas - it is all in the manual and help section.
Mike
Please put questions more specific.
On your installation dvd or cds there is a reference manual. There youll find all about calendars and resource assignments.
Calendar: Per resource or per activity - a default value per project for new activities.
Assignments: Units depend on duration type, the default per resource, individual entry possible per day or for the hole assignment. Curve is possible. Some parameter settings for the project must be regarded - under tab "Resources" and "Calculations".
Good information on these items youll find in the "Help".
Did you consider to join a training?
Good luck!
