Staircase Construction- RCC
S
Saju TS 👤 Member for 17 years
Dear all,
When can I start Staircase work
1.Ground floor slab
2 .Columns
3 .beams
4. RCC walls
5. First Floor Slab
6 .Columns
7.Beams
8. RCC walls
9.Roof Slab
From where i can start  RCC staircase construction
M
Hi Saju
You have to have at least two slabs to support the staircase and it can follow the structure upwards.
It depends on the construction method statement because the stairwell may be used for vertical access and hoists.
I would also consider a precast option which can be dropped into place in one day.
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
fridau
