Production and Maintenance Planning
M
Hi All
Aahraf is right.
If you can’t do it you can’t plan it.
Mike T.
C
Carmen Arape 👤 Member for 22 years
I do believe that time of crisis is time for opportunities.
Crisis in EPC projects, may be is the time for looking at operation & maintenance planning.
Can anyone recommend sites about planning in this area.
Thanks & Cheers,
Ashraf Jahangeer 👤 Member for 19 years 2 months
You can always to go to any field you like.
Start as Asst. planner and try to learn the tricks of the trade and move on.
There is no specific course the skills will come to you by experience only.
Ashraf
M
moutaz aldeib 👤 Member for 22 years 6 months
Thanks Ashraf,
But I have not worked in this field before, what you wrote it means that I can not go into this field.
Is there specifice intensive course in this field or good book?
Moutaz
The requirement for production and maintenance planner is usually the following.
1) Have highschool / certificate course as qualification, if you are a Diploma it is sufficient.
2) You should have around 10 years experience in production/maintenance field.
3) You should be aware of maintenance cycles of major equipments eg. for colums / vessels it is 3 years for cleaning and 6 years for full inspection.
4) You should be aware of maintenance spares etc. which need to be replaced during overhaul.
5) You should be aware of maintenance tools and tackles.
6) You should have fair about the time required for maintenance activities e.g. hydrojetting of a heat-exchanger etc.
The list is bit long but the bottomline is you should have worked in the maintenance environment for long enough as planners are most important person in maintenance and production.
Ashraf
Catalin Suditu
Laraib Fatima
Adrian Fletcher
GeoVe
Abkar Bannayan
christiandt
J Vaartjes
Aidar Kurmantayev
Noe Radovan
