Home Cinema
H
Hemanth Kumar 👤 Member for 23 years 8 months
Thank You
I Discussed With My Supplier and Formulated The Plan
Thank You For Your Interest & Helpful Mind
S
Samer Zawaydeh 👤 Member for 17 years 11 months
Dear Hemanth,
I have checked with our local Low Current Supplier, and they informed me that it is totally dependent on the system that you are installing.
So I suggest that you discuss the issue with the supplier and formulate a completion plan as per his sequence of work.
Samer
H
Thank you sameer
but i was looking for the finer details
install projector,lay HDMI cable , install speakers etc
S
Dear Hemanth,
Kindly consider the following:
1) Material submital approval
2) Shop drawings approval
3) Procurement
4) Construction
a. 1st fix: After block work and before plastering
b. 2nd fix: before complete plastering
c. 3rd fix: before complete painting
5) Commissioning: few days before handing over.
6) Programming: after moving in
If you need more specific detail, the best source would be the specialist who is going to install the system for you.
Samer
Featured Partner
Zine Eddine
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
