MS Project Server - Project Interim variance
S
Stephen Grady 👤 Member for 22 years 11 months
Thanks Brian - that works!
I must remember to select the "use Formula" option in future.
Steve
B
Brian Ultican 👤 Member for 19 years 1 month
In the customize field dialog there is a section called "Calculation for task and group summary rows". In it select "Use Formula". This will have the variance calculated at the summary task levels within your project, including at the project summary task level.
Remember to use an Enterprise level field if you want this to be calculated for all your projects.
Featured Partner
Zine Eddine
mxsiegel
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
