& Sign In Footer
Alexandre Faulx-Briole 👤 Member for 23 years 5 months
Hemanth,
thanks for having documented something deep in MS Project!
"&s" = Project Start Date
"&S" = Subject,
a.s.o.
Alexandre
H
Hemanth Kumar 👤 Member for 23 years 8 months
Thank You All For Valuable Tips
Sorry For The Delayed Response.
Some of YouDon’t Get weird results Because Probably Most Of your The Project Properties Fields May Be Blank
Pleas Fill All File > Properties
Here Is What My Project Properties Are
"1: Title: Master Plan"
"2: Subject: Car Plant"
"3: Author: Hemant"
"4: Keywords: Mazda"
"5: Comments: First Draft"
"6: Template: DubaiOrganised"
"7: Last author: Hemant"
"8: Revision number: 99"
"9: Application name: MSProject"
"10: Last print date: 01-Apr-07 9:36:00 AM"
"11: Creation date: 25-Oct-06 8:45:00 AM"
"12: Last save time: 01-Apr-07 9:41:00 AM"
"13: Total editing time: 5"
"17: Security: 0"
"18: Category: For Owner"
"19: Format: "
"20: Manager: Andrew"
"21: Company: XYZ"
"29: Hyperlink base: C:\All Projects"
"Custom Properties"
"1: % Complete: 0%"
"2: Cost: Dhs0.00"
"3: Duration: 714d"
"4: Finish: 09-Apr-09 7:00:00 PM"
"5: Start: 30-Dec-06 7:00:00 AM"
"6: Work: 0d"
"7: % Work Complete: 0%"
Now
When I enter Andy&summers
What I Get Printed Is : Andy 22 Feb ‘06ummers
(My Project Start Date Is 22 Feb’06 , Project >Project Information >Start Date)
And An entry Of Andy&Summers
Get Printed Like This : AndyCar Plantummers
My Idea Of raising this Issue is to make those unaware of this issue aware, And Avoid Unwanted Printouts.
Thanks for the interest of you all
Hemant
B
Bo Johnsen 👤 Member for 20 years 4 months
Hemanth,
You could also just add a space before and after the "&", i.e. "Ram & Company" instead of "Ram&Company" and so on. That works for me also for line 2 and 3 in the footer (MS 2000).
Therefore "This & That" would work, but not "This&That".
Bo
H
Thanks Alexandre
This Sign not only add page nos but adds a host of other things like Project Name , Default Company Name Etc in different instances.
No Falt Solution , As You Said, Delete It Manually
Hemant
Hemanth,
I tried one line at at time, and it works perfectly; but it does not work when you enter the four lines together, "Mather&Platt" becomes "Mather1latt", "Refer ..." => "Refer page 14", "Collins&Partners" => "Collins1artners"
Reason is that MSP (I am using MSP 2003 Pro) is adding "[Page]" after each "&" after the 1st one; browse in the lower frame and manually delete the offeding caracters.
Alexandre
H
Dear Friend
Enter The Following In a project footer
And see the results (!)
Ram&Company
Mather&Platt
Refer Page 1&2
Collin&Partners
Enter Exactly As I Typed
Thanks & Regards
Hemanth
Hemant,
You can use "&" sign as normal & sign in Footer as per your example "This & That" and it will appear as normal as long as it is not followed by bracket sign "[". ie "&[]"
This bracket sign refresenting memory variables or field exist on MSP. ie: &[Page], &[Start], &[Finish], &[Time], &[Date]
Rodel
Luis Jr Ngade
Ben Welsher
Rohan Dashputre
AMECHI ANAKWENZE
Jayaprakash Sekar
arash.karmand
Vahidazimi01
David Smith
Peter Holroyd
