You can enter the ACTUAL WORK (hours) by changing the VIEW to TASK USAGE. On the right-hand side of the screen, you will see the cells that enable you to input the actual hours completed, on whatever days you choose. This will then automatically calculate the % Work Complete (hours). If you then change the remaining task duration, this will automatically change the % Complete (duration). However, you must be careful, because when you change the remaining duration, you are also likely to automatically change the Remaining Work (hours) - thus altering the % Work Complete.
There is no One-Button solution. If it is a Fixed Unit task, then changing the duration will automatically change the hours. If you dont want this to happen, then you must change the task-type to that of Fixed Work.
thanks for trying to help me but my tasks in the project are fixed units tasks when i did what u said i found out that % complete and % work complete are the same value while its a project for installing pipes and cables and some other stuff like air conditioing units
so i really can get it and im the consultant which is playing a part with the project owner and i have to follow the contractor if he is behinde the schedual or not??
19 years
Member for19 years
Submitted by Rodel Marasigan on Fri, 2007-05-11 11:18
% complete is duration and % work complete is resources or hrs. There are many ways of entering progress. You can double click the activity and enter percent complete from general tab of task information dialog box or by inserting column to show % work complete and % complete. Another way is to display the custom form icon from toolbars. View-> Toolbars-> Custom Form. Then select the form Work tracking.
19 years 5 monthsRE: ms project
Ahmed,
James.
18 years 9 monthsRE: ms project
19 yearsRE: ms project
Ahmed,
HTH,
Rodel
