TIA and Tons of other Schedules.
19 years 10 months
HI Sajid
I have never yet come acros a form of contract that specifies a particular method of delay analysis.
Perhaps yours has a special condition written in.
Everything relies on how good your As Built records are.
Ideally you should be able to demonstrate Who Did What Where and When.
The best fall back position is to know when each activity started and when it finished.
If you do not have that basic information then a Time Impact Analysis is not possible.
I have set out the steps necessary for creating a time impact analysis elsewhere on this thread as have a lot of other contributors.
I suggest as a first step that you search the forum for advice.
18 years 5 months
>>The first question to ask is why use TIA when there are a number of alternative methods that may be more suitable.
The answer is Conditionsof Contract
>>I am sorry to have to tell you Sajid that you are out of your depth on this task.
That is THE reason I am on this forum.
>>Someone may send you a web address for aace which I have read and found it unreadable and misguided.
Every bit of information is knowledge for me. I need to make an informed decision rather than I say, I CAN’T without knowing the much of the detils.
>>You may get better response from the SCL protocol which is clearer but out of date now.
I do refer SCL Protocol for quite some time now.
>>In any case you can’tlearn delay analysis from books.
True, and thats the other reason I am on this forum. I need some hands on knowledge rathe the theory of something.
I hope I may get some more expert opinion on this thread.
19 years 10 months
Hi Sajid
And how will you know which is the better alternative?
18 years 5 months
Hi Mike
Pease find my replies to your reply.
>>Any advice that I can give you on PP will not be sufficiently comprehensive to solve your problems.
But, I still looking for "ANY" advice. How should I say without knowing that what is required and why we need expert delay analyst.
>>You need expert delay analysis advice dedicated to your problem and this will cost money.
no money with us for such experts.
>>Explain to your employer that you will need this assistance.
In view of economic downturn, I opt not to take this advice at this time.
19 years 10 months
Hi Sajid
