Schedule Risk and Schedule Risk Analysis
Description
The Risk Aspect of Planning & Project Management
Container
No
Weather window - adding the resource
I am trying to add a weather window to the normal winter shutdown.  In PRA, this is accomplished by adding a resource defined in the Weather Modeling module.  My question,  is there a global change in P6 8.1 or a macro in PRA 8.7.2 that will do this?  I am currently doing a sort on a resource, then adding the 'Winter' resource, copying that cell and doing a fill-down.  Then repeating for each resource.  It is functional, but tedious.  Any suggestions welcome.  Thanks.
Primavera P6 Critical Analysis
Rhys Parry 👤 Member for 14 years 8 months
Hello
I have a plan in P6 version 2 and after updating activity % and my Expense % Complete to match then schdulling it the end date for the enture project plan went from for example 12 october to 12 november.
I don't know why this has slipped so much as I was thinking it could be to do with some of the Level of Effort activities I have.
Any Ideas guys (can I do a timeline of events to see why the dates have changed so much)
PRA 8.6: Why do Oppty Hammocks cause zero TF?
Background:  PRA V8.7, using opportunities within the risk register of PRA
My PM wants an explaination why an activity (that contains an oppty node) with 1.5yrs probilistic float has a
100% critical index. From what I can see it is the hammock off the Oppty node
with zero total float causing it.
Is there a valid reason why this happens?
Thanks in advance,
Kevin
Using Crystal Ball for Simple Analysis
Looking for 'Idiots Guide' type assistance with Crystal Ball (Oracle) as Excel Supplement.
Have never used the Software, downloaded yesterday, and I have to come up with some P10, & 90 Durations for a Manufacturing/testing/shipping schedule due to be received next week.
Would use the Manufacturers Schedule Durations as P50 Input.
Can some one please advise how then to get the P10 & P90 dates.
Thanks.
Looking for Decent Risk Software
J
Jay S 👤 Member for 17 years 11 months
I am looking for Decent Risk Software
I have the following requirements
1) Integrateable with Primavera and MS project
2) Easy to use
3) Consider Lags and Logic as part of the Risk Assesment. (Example) Optimistic Logic FS-10D /  Pesimistic = FS +5D / and FS
Phase Planning using Monte carlo
Dear all,
I have a following doubt can any give me suggestion how to do that,
I have 1 master project with me .it Consists of 3 Phases .I want to calculate the project duration,ie the best duration .
I like to know how Monte carlo Analysis fit in it.If i give a range of values as input ,ie max & min time for each phase it might give range of output.but my doubt is how good is it(duration)? These 3 phases are dependent each other.
Sankar Vijayan
Monte Carlo Risk Analysis
Dear all,
My self sankar vijayan.I am a fresher in  construction field .Ia m now working with a MNC now .My boss told me to prepare Risk Analysis for a project.While doing it i came across this Monte Carlo Risk Analysis.I refer some articles in net.Can anyone explain with small example pratically how to impliment it without using any specialised software.So that i can recomend this method to my boss.I am from Tendering department.
Sankar Vijayan
