Oracle Primavera - PM6
Description
Here's a place to discuss some Primavera Enterprise questions
Container
No
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Schedule Filters with WBS or codes Not Transferring
Hi all,
I've made several filters within a P6 schedule to show certain WBS sections, and FOW assigned codes.
I know how to save the layout, export layout and import again to transfer filters between schedules. For some reason however, P6 doesn't want to transfer those filters that include the WBS sections or FOW assigned codes. Those parts of the filters show up blank.
Has anyone experienced this or know why P6 behaves this way? It'd be nice not to have to re-do these filters with every schedule update I import.
Thanks!
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Export relationships to .xlsx Excel
Hi everybody.
This is my first input to planningplanet. Sorry if it was answered in the past. I coudnt find anything about it.
The point is that the projects I usually hande have more than 65000 relatioships. I use P6 version 15.1 and the only export format I get is in Excel (.xls). And that kind of excel have a limitation of 65000 rows.
Is there any way to get an export on .xlsx (Excel 2010 or above) directly from P6? It's getting impossible to export all relationships at a time whe my projects reach maturity.
Thank you in advance
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Unable to print profile in Print preview>page setup
Dear All,
I got P6 re-installed on my system as the oracle database crashed, now i am working with SQL server. After the new installation i am not able to print profile which was earlier available in the print preview options. Please advise.
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Is the 64 bit SDK .xls file available ?
S
Shaiju Pv 👤 Member for 10 years 7 months
The .xls SDK files downloaded from oracle support is not working in a 64 bit OS/Office.
Its giving an error to update the VB coding to 64 bit(The oracle file created in a 32 bit OS).
Is there anyone updated the codes to 64 bit ? or from where can i get the 64 bit files
shaiju
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Missing activities after restoring the copied Baseline
I have a very strange problem with many aspects,  I will illustrate it at the following points :
1. this problem occurs with many project not only one and at different PCs
2. When copying an Assigned baseline from inside a project from the maintain baseline window then pressing restore button,  the restored baseline is missing 95% of its activities with a corrupted WBS structure with so many empty _with no activities _WBS levels,  I can restore the original baseline with no problems after removing it from the assign window.
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Loop checking in V 8.2 and 16.2
I have been previously running 8.2 using progress overide on the programme. Occasionaly I have inadvertantly added logic that created a loop that was detected and removed from the programme. Otherwise the scheduling wont run.
This month we upgraded to 16.2 and following a normal monthly update and re-plan and many scheduling runs I ran a sched log that detected 28 loops that weren't flagged when running the scheduling.
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
summary bar label
J
Jason LI 👤 Member for 18 years 5 months
All,
I'm organizing the layout using activity code, all the activity names are using English, and at the right side of the bar, I'm showing the bar label use another language to translate the activity names, so the people didn't know English can read the schedule.
My Question is: are there any way to showing the same for the summary bar (the summary bar label only can show the description of the activity code, but i don't want the activity code description be bilingual)
Thanks for your reply.
Vahidazimi01
David Smith
Peter Holroyd
fridau
Rahmat Hidayat
pinoyplanner
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
