(first sorry for my english) i m entering a new value in the duration % comp field then i schedule but p6 doesnt update my new value.p6 hold my old value how can i solve this problem thnx
duration % comp doesnt update
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Ferhat,
Check activity type. It looks like Activity Type is "WBS Summary". P6 will never let you update the % of WBS Summary activity and it will bring % back when you reschedule.
Syed
Ferhat,
Had you set the activity as started by checking the check box beside started?
And are you a poweruser of the program?
Hi Ferhat
It seems that i cannot help you any further . Are you sure that you are displaying the correct column for "duration % completion"? You can check this by verifying whether the % completion in the status tab is the same as the display in the column you are using.
Maybe Raymund may have a solution
Johannes
Hi Johannes
my activity % completion type is duration.And i assigned baseline.i didnt add new activity or delete.but duration % comp doesnt change.i m checked the other projects on p6.on my project "Link Budget and At completion for not started activities"
is not active and i cant mark it maybe problem is here?
Ferhat
There are several reasons why the updating of the duration % completion are not showing.
Regards Johannes
