P6 deleted resources
Deleted resources from main heirarchy,refreshed data and logged out. On next login deleted resources where reinstated on list ? Any ideas what could be causing this issue. This does not happen when using the web application.
Alan Chadwick 👤 Member for 22 years 11 months
On the sa,e topic as deleted resources but a different scenario:
I have allocated the same resource to the same activity twice, within the project setting I have the check box -
Resources can be assigned to the same acivity more than once checked.
However when I export and then reimport to another database only a sigle resource gets carried over.
Example
Activity 1 has R1 allocated twice, when imported R1 only gets carried over once
Example
K
Ken Catherall 👤 Member for 13 years 7 months
Thanks Ronald, it appeared that IT had run a back up after problems with main server. Thanks again for the lead.
Ken,
 Could be that the IT re-loaded a backup of the database.  Otherwise, perhaps someone else was also logged-on with the same schedule and logged-out later than you (thus re-saving the resources).  I believe that the correct procedure is to login with exclusive access before deleting these types of items.  Good luck!
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
